K
kylen
Who puts a mastering limiter (or anything else) across their master buss while mixing? Maybe not the entire time but to check out the mix to get an idea how it will sound when the mastering engineer pushes up the loudness a bit.
What kind and how hard do you push ? Depending on the type of mastering limiter and how hard you push it can change the balance of quite a few things obviously...
For example, if I had to guess I say that somebody like fenix might put an L2 across his master buss at some point during mixdown to check things out.
What limiters are you guys using for this ? And if you're not - jump in too - maybe you'll say something like - I can make my mixes as hot or as dynamic as I want without checking them thru a mastering limiter...maybe you're running stems thru some limiters while you mix then...
Just curious
Just curious
