Treeline
I had this whole thing figured out in my studio. Now my goddamn computer won't boot and I have to start all over again with the wire recorder. And I thought I was finally done with it.
Or, to simplify it even more:Here's how to avert the 500 page GS thread:
- People who choose to mix all analog and can't produce a decent track suck.
- People who choose to mix all digital and can't produce a decent track suck.
- People who use a hybrid approach and can't produce a decent track suck.
- People who think anybody who doesn't use the same approach as they do sucks suck.
- You suck.
- I suck.
- GS sucks.
That about covers it, I think . . .
Computers didn't always have hard drives. The computer is the thing that computes, the hard drives, DVD drives, firewire ports, USB ports, etc... are just peripherals attached to the computer.a computer has a hard drive. My digital mixer does not.
A digital mixer is just a computer with a built in proprietary DAW and control surface. The only thing it's missing is editing capabilities, otherwise it works pretty much the same way cubase attached to a control surface works.
I have a digital mixer. Sometimes I will use it to monitor each individual track that's in Logic. It has decent eq and effects. At times I will use them then bounce the entire song down to disc on an external cd-burner. I have a Philips cdr770. I consider that to be OTB.
Yup. Mixing OTB, to me, means summing analog. YMMV
Really?... With analog voltage it is infinite resolution as long as your source is good quality.
...With good Reel to Reel machines and vinyl cutter machines analog is a continous analog wave form and it is capturing the full spectrum of the orginal analog audio wave source.
..Digital sampling on the other hand samples intervals of analog audio and it is definately missing some of the information in the original wave form of analog.
If it were true that analog captures the signal more accurately, why do different analog machines all sound different?
Do a A/B comparison test for yourself.
ITB/OTB Digital/Analog.
It.Doesn't.Make.Any.Difference
If you can't make GREAT sounding music using any combination of the above then you're wasting your time because it's not the tools - it's YOU
That is the most important point you made. Everything else you said can be debated, and most probably will. It is the perennial battle of preference; a battle in which there is no winner.
But even A/B tests aren't satisfactory if you know which is A and which is B. A better method is a double-blind test.
It is sad, because when that day comes when young or old can no longer maintane the analog gear they have (they have already pretty much stopped making analog gear, and or have given up supporting or fixing the analog stuff, and it may stop being available on the used market ?) then the art of analog audio and its gear will be lost forever.
Like I said, almost anyone can hear the difference, but you seem to be confusing 'sounds nicer' with 'more accurate'. In a matter of speaking, the sampling resolution isn't any better than digital because the actual audio signal is used to modulate a ultrasonic bias signal in order to store something on the tape that is anywhere near linear.Well the thing I argue about, not trying to be forcing my opinions on anyone, is that the analog tape medium can be, and in my opinion is far more accurate than digital because of its analog sampling resolution. 2" analog tape will be as close as you can get to the original analog audio. It's not just my opinion but many others hear this difference too.
Again, are you arguing that it sounds fantastic, or it's more accurate?But most people will not be able to use 2" analog tape today let alone be able to afford the tape and the machine to record on. But even still using 1/4 " analog tape and even cassette tape can still sound fantastic, even though it has a little more tape hiss.
And digital doesn't suffer from distortion from tape saturation, tape bump, hysteresis, etc...Yes analog tape has its flaws and a bit of distortion, but it capures more of the original analog signal and has less distortion from sampling errors than digital does.
I spend years working in analog studios with 2 inch tape. Frankly, it drove me nuts that what I recorded isn't what came back off the tape. The time I wasted making slave reels so that I didn't wear out the master tape doing endless overdubs still annoys me almost 20 years later. Of course, if I didn't do that, the rhythm section would keep getting duller and duller sounding as we kept overdubbing vocals and solos.What this is worth to you is probably not much, because you may never use analog tape to hear the difference. Especially when analog recording gear is getting less (and less affordable) relevant today for the sake of digital being more popular due to digital being able to capture music almost as well, and more easily edit and transfer audio much more quickly. Digital appears to win everytime in this regard.
