Mixing and audio card
  • Thread starter Thread starter DRUM
D
DRUM
I am wondering how digital mix is done!
Does audio card play any role?
I understand that card is most important for recording, but what about mixing?
Is it just processor what does the job?
If that's the case does it mean that we don't need audio card for mixing but for recording and playing only?
I am so confused :confused:
The quality of a sound care does matter for mixing.
You just don't need all the inputs that most cards for recording have.
But what you do want is something with ASIO support. That will help in mixing with live sound effects.
For a few tracks of mixing, and limited effects, a common sound card will work, since the only interfacing you need is a stereo output.
Do keep in mind that cheap "soundblaster" or built in PC sound cards will have less than stellar D/A conversion and high noise. So you'll think your mix sucks, when it's really the sound card that sucks.
The computer "sound card" (I prefer the term "audio interface", as sound card usually infers only a specific class of interface) is important for determining the quality of the audio going in and out of the PC. In other words, audio being recorded to the computer has to go though the sound card first, and when you play it back to listen to it, that playback signal is sent though you sound card to your speakers.
The sound card, however, has no direct effect on the quality of your mixing on the PC, other than how it may affect the sound of your speaker playback. The quality of sound mixing is determined mostly by the software itself - both the mixing software and the plug-in software.
And yes, with a few rare exceptions, all the mixing work is done by the computer itself. The main difference computer configuration (CPU speed, amount of memory, etc.) makes is that it'll determine how much horsepower you have to mix with, which in turn will determine how many audio tracks your software can run at once with how many simultaneous plugins per track. The faster and larger you computer config, the more of each.
There are two main exceptions to the computer doing all the work. First are those plug-ins that take advantage of seperate dedicated processor cards to do their work. Examples would include the plugs from UA and Sony Oxford. These tend to be the most high end expensive plugs (usually costing more than the computer itself these days.) The second would be those plug-in sound cards that have their own MIDI DSP (Digital Signal Processor) chips on them for performing MIDI track processing.
HTH,
G.
OK!
Let's say I use midi and VST instruments only!
In that case my sound card is used in the mixing prosess.
In the other case (WAV-files only) I don't actually need this card for mixing cause I get audio files recorded somewhere else and burned on DVD-R.
I can import those files to my project and add any intern efect I want amd mix it on my powerfull PC not depending of expencive sound card?
Or CAN I?
I don't use any external hardware or plug in.
thanks
