E
Elton Bear
Unregistered Abuser
Could I use an insert send as a direct out? I'm looking at getting a Peavey PV14 mixer (non-USB), and want to record each track separately, but it doesn't seem to have direct outs - is it possible?
Very true but I see this as a VERY good thing. Just the trim controls the level going to the recorder and the EQ/Fader can still be used (along with any effects patched into the mixer AUX sends/returns) for monitoring. What goes to "tape" is not affected by any EQ/Fader moves during tracking.JCM900 said:yes, but bear in mind, that most inserts are pre eq and pre fader.
Not if one is more clever than the board, Weedhopper. The send would be unbalanced any ways, so what you do is to modify an unbalanced cable by soldering a stereo type connector at one end with the pin and ring soldered together. This way when you seat the plug in the insert, you'rer just tapping off signal for the multitrack and the signal will also continue through the channel strip as it normally would. You can control the level in a monitor mix (and EQ) without affecting what's headed to tape.Riverdog said:Ahhh yes! BUT - If you use a direct out, doesn't it need to come back to hear it through the board???
So if you use a direct out - it removes the signal from within the mixer path... therefore, no sound...
Thoughts????
I do something akin to that. I have the channel inserts of my Mackie 1604 connected to half-normalled points on one of my patchbays. Instant access without interrupting to the main outs.Track Rat said:Not if one is more clever than the board, Weedhopper. The send would be unbalanced any ways, so what you do is to modify an unbalanced cable by soldering a stereo type connector at one end with the pin and ring soldered together. This way when you seat the plug in the insert, you'rer just tapping off signal for the multitrack and the signal will also continue through the channel strip as it normally would. You can control the level in a monitor mix (and EQ) without affecting what's headed to tape.
I haven't tried it myself on this mixer, but I've seen this recommended before, so I thought I'd chime in. This will work well enough if you are not skilled enough to modify the plug...Track Rat said:The "first click" connection will work but I've had them be intermittent before. With the modified cable, you can fully seat the plug and the connection is pretty solid then.
