T
t2roc
Im looking for an interface. Its between The Echo AudioFire 4:
and Presonus Firebox:
Or im thinking of getting the Mackie Onyx 1220. It seems like a good price . But this makes me think twice.
also found TAPCO BLEND-16 16-CHANNEL MIXER W/ MACKIE PREAMPS
$379.99
:http://www.shop.com/op/~TAPCO_BLEND...E_PREAMPS-prod-38392922-50995733?sourceid=298
"It is the FireWire option that causes mixed feelings for this reviewer. On the one hand, the Onyx 1220 board by itself is simply outstanding and puts my old Mackie 1202 board to shame on every level. On the other hand, the FireWire option isn’t all that it is cracked up to be. Or I should probably say the FireWire option works the way it was designed, but not the way I had hoped it would work.
The biggest thing users who are considering buying the board with FireWire option should know is the FireWire audio output is post gain only. This means you are only able to send the raw signal from the mic/input to the DAW. This means you can’t use a compressor, any part of the EQ, mute buttons, panning, and so on. And this sucks, at least for me. I really wanted to use my Alesis 3630 compressor to tweak my vocals prior to being recorded by Soundtrack Pro. While DAWs do have compressor plug-ins, I find these rather clumsy and don’t yield the same results I can get by manual tweaking a piece of hardware.
Instead, the FireWire option for the Onyx 1220 mixer only allows the capturing of the raw feed, which, if you think about it, gives the audio engineer the ability ultimate control of the mix in post. And this makes sense from a live recording standpoint, but is still a disappointment for me
If you need to capture only the raw audio file to your digital audio workstation, and if your application will support multi-track recording, then this is a very useful addition. My disappointment of the FireWire features only give it 2 of 5"
Is this a problem for anyone. Anyone with experience of these products or
ideas. cheers Michel
$379.99
