Myriad_Rocker
xstatic said:Actually, if it's any kind of heavier rock, the over curve in the picture you posted isn't too far off. There does seem to be a pretty good high end lack at about 8khz and up though. I would try knocking a little bit of 160 off your kick, and give it a nice little boost at 3k and at 8k. That should help it a little. You may even need to turn it down a bit after that.
I did some EQ on the kick and it's sounding pretty good...more attack and less boomy so that's good. I also listened to the mix on my home stereo....MUCH MUCH better sounding. It is lacking a tad in the high end though. Probably another limitation on my monitoring chain. I'll boost those freqencies a tad or cut some around them.
