Nola
All good.
Thanks!
Thanks!
Thanks. Is there a way to keep high reverb yet remove the wooliness of it? That must be what I'm hearing. But, our band likes a ton of reverb just an a stylistic effect so we'd like to keep it. Would sending the vocal reverb to a bus that has an EQ curve cutting the highs and lows/low mids be the way to do that? I'm using Valhalla so maybe it has that option I'll look.The Sound of the Demo is pretty on par with the Original - the Organ isn’t too wooly - the Vocals are - Back off the reverb a little bit.
Put a EQ Plugin before the Reverb - cut between 180 hz and 400 hz out - you can leave it high in the mix.Thanks. Is there a way to keep high reverb yet remove the wooliness of it? That must be what I'm hearing. But, our band likes a ton of reverb just an a stylistic effect so we'd like to keep it. Would sending the vocal reverb to a bus that has an EQ curve cutting the highs and lows/low mids be the way to do that? I'm using Valhalla so maybe it has that option I'll look.
Here is an updated mix. Is the vocal reverb any better? I cut out some lows and mid lows in the vocal-reverb vst and then used a slightly higher predelay. I also raised the mix's gain by 2B and thickened up the acoustic guitar a hair.
