M
monstermaker
Used search but couldn't find anything on this.
I'm hooking up a drum machine to Sonar 2.0. I'm getting mild distortion on bass notes at playback. All the input levels are ok.
It's sort of a slightly distorted slap back type echo on the lows.
Thanks for any help.
Playback indicator is different with with record indicator. So be sure to set the led indicator to monitor signal recorded. Anyway, you didn't say your Sound card. Check your windows kernel mixer (right hand corner, taskbar) for recording property, and make sure it's not all the way top. 70 - 90 % of the slider length. Last thing, is to lowering every volume, and record. Step by step, push up the level. See, in what level the distortion appear.
