Miking a kit up and converting hits to MIDI signals?
  • Thread starter Thread starter jndietz
J
jndietz
The Way It Moves
Anyway to do this? I want to mic up a kit and route it into EZD/Superior 2.0 through FLStudio in the Piano Roll. Also would it be able to detect velocities?
TIPS?
Triggers and a MIDI drum module like the Alesis DM5
No mics involved in this option but it will be a lot easier than trying to convert audio to MIDI in a software invironment.
I use an Alesis DM5. Just take the output from your mic preamps and feed the trigger inputs on the DM5, assign the triggers to the corresponding instrument family/MIDI note #, plug the MIDI output of the DM5 into the MIDI interface of your sequencer/DAW, hit record, play drum kit
...and then prepare yourself for a long night of massaging MIDI data.
Not elegant, but it works.
Yeah, the Alesis unit will do it if you're on a tight budget, just don't use the thing on its own for drum sounds (uuuggghhhh). Roland products react MUCH, MUCH better from a realism and sensitivity standpoint. The Alesis may not pick up that small snare ruff, or that light, jazzy tom hit, but Roland will. Just depends on what you need. Either unit (I recomend the Roland TD-20 by the way) has the midi outs you're looking for.
Check out some of the videos on Drumagog. You can even make mic triggers out of old headphones.
