tubedude
Ok,
I am having a problem with Sonars midi timing and DR-008...
I go through and put in a kick pattern, and on playback the kick pattern is fine and on time. Then I'll go back and put in snare pattern with it, and the kick is still fine, but the snare plays back with terrible bad unpredictible latentcy, like more than 1/2 second. If I watch it in piano roll view, the kick will fire right on cue as the now time passes over it, but when it passes over the snare, it'll be 1/2 second or more before the snare makes any sound. If I watch the DR-008 screen, the pad on it doesnt light up until I hear it, so I'm sure its the sequencer somehow not firing the note correctly.
Also, I tried moving the snare track to a track of its own, and it still fires with the same bad latency. Also, if I stop the project and restart it, it will always fire the 1st snare from wherever I start it on time, but not the rest of them.
Can you give me any idea whats wrong so I can get working again?
Thanks!
Thanks!
