MIDI & FL studio issue.
  • Thread starter Thread starter mikkas70
M
mikkas70
I've bought my BCF-2000 a few months ago. Everything is working fine using Fruity Loops (I'm using the BCF via USB connected to the PC).
Today I bought a MIDI cable so I can connect my synth to my BCF via MIDI .
I did that and the light saying "Midi in" on my BCF is now up, when I press any of the keys of my keyboard it blinks, which means that the MIDI signal is being recieved on my BCF. But for some reason the keyboard isn't working in Fruity Loops, the BCF is still working but my keyboard is not, even recieving the signal on my BCF.
Does anyone know what is this problem and how to solve it?
Apologies for my english.
The problem is that you're expecting the midi information to merge from USB to the standard midi ports and the BCF is not set up to do that. If you have a midi in port on your interface you'll need to run a midi cable to it from the BCF midi thru port and then your keyboard should work. You may be able to use USB and standard midi ports at the same time. Try it and let me know.
