Ford Van
Banned
Okay, at the LEVELS that most guys end up playing their amp at, 18" away you will get so much direct signal that the "room" is going to be VERY LOW in volume, and I can almost totally assure you that you would not be able to tell what kind of room it was done in.
Remember, the sound will excite the room in unique ways. The way a snare drum reverberates in a room is TOTALLY different than the way a bass guitar will reverberate in a room. In the "delicated" 2-5KHz region (about the SMACK of a snare drum), or course you will hear the "room". But, low frequency reverberation is VERY hard to hear!
Phase problems will not be much of an issue either because of the 3:1 rule.
18" is pretty close. It isn't far enough away for me to consider it a "room mic" by a long shot. 4'? Sure.
The statement I referred too is FAR too over simplified, and simply, just not true! I have recorded plenty of stuff with a mic in untreated rooms where the mic was close enough to render the room a non factor.
If you are REALLY FUCING BLASTING something in a room, and you are using a mic fairly close, THEN the reverberated sound will start to become an issue. But, if that is the problem, well, TURN DOWN a bit!
