microphone connection and lightsnake
  • Thread starter Thread starter Doodoo191
D
Doodoo191
By being a cheap idiot I just bought a Lightsnake. It's generally used to connect a guitar or other instrument to a USB on the PC. However, what I wanted it for was to connect a dynamic mic. It's connecting, and recording, but it's not boosting the signal enough, and it's ridiculously quiet. It came with a 1/4" to USB cable, and a splitter that goes from 1/4" to two female 1/4" and that's how I've got it hooked up. Before I go to Radio Shack for another connector, or just to return this thing I thought I'd see if anyone had an opinion. Thanks in advance.
Cheers,
Chris
Well any Dynamic Mic is also going to need a preamp and I don"t think they have Squeezed a preamp inside that small cable, so without the Preamp the Mic will be very quiet because it"s signal isn"t strong enough....
If yopu had a Battery Powered Condencer you would get a Better signal because Condencers have a Built in Fet Preamp which gives them a Good Signal Boost over Dynamic mics.....
Cheers
Allright, thanks guys. that's kind of what I thought, but I wanted an outside opinion. I really don't expect the guys at Target to have a decent opinion.
Buying recording gear at target was mistake one.
Rather than trying to build it yourself I would look at a low end preamp, but all in all I would be worried about the quality of A/D circuits that they crammed into the head of a cable.
I would send the lightsnake back and get this
http://www.sweetwater.com/store/detail/FastTrackUSB/
What is Lightsnake?
...or see it here lightsnake.com ;-)
Not just the A/D. The analog components would probably suck, and even if they don't, most of those super-cheap USB audio devices like that have latency that's measured in units of tenths of a second.... :D
