D
drummerboy_04AP
What is your approach to micing the singer/songwriter type who insist on playing and singing simultaneously?
Got that right.Good luck, cause recording a dude with his guitar is not the easiest task!
And rightfully so, because you'd essentially have a defective mic.i.e. if the vocal "bleed" (there goes that word again) sounds like muffled crap from the perspective of the "guitar" mic ... then it's not contributing positively to what the "vocal" mic is trying to do, and vice-versa.
If it's less than a foot, it isn't "bleed".
Except that the cool thing about dual 8's is that it attenuates quite a lot of the cross feed and the phase holes between them. Still forces compromises as to mic position and angle but those nulls are amazingly focused...You can't look at it in terms of isolating the voice and/or isolating the guitar. You can't even look at it in terms of "mostly" isolating anything. You have to approach it from the perspective that you've got two tracks; one of which will give you a little more voice than guitar, and the other will give you a little more guitar than voice. ..
Track it this way, pan the LDC straight up, the SDC hard panned and then flip the phase of the SDC.
Helps everything to sit pretty well.
Mono compatibility is over-rated anyway.
Ick....but,...if you insist,...I'd try an acoustic / electric,...or a sound-hole pickup..
