cjacek
Analogue Enthusiast
I'm having a bit of a hard time deciding on gear setup, probably due to being confused. Specifically, I used to record with a mixer where I "inserted" the compressor. In essence I got to comp the mixer's preamps going into the recorder. Currently I record by going straight from my EV 635a dynamic to reel to reel recorder. I have a compressor as I always liked to comp signals a bit going in. I know I need a mic preamp before the comp. The BIG issue here is that I thought I needed a mic pre with an "insert" 'cause I was used to that already but then someone suggested that all I require is a pre which goes "out" to my comp and then recorder. The recommendation there was that I don't need an "insert". Ok, that's fine but I am worried about distorting the preamp. Sure, it'll pass the signal to the comp and onto the recorder but I'm worried about distorting the pre. See, whenever I use my mixer's "insert", I never had to worry about that as I was comping the pre first. Can someone offer any suggestions ? Thanks!
Daniel
Daniel
