dainbramage
Beat me with a verbal baseball bat if I'm wrong, but wouldn't panning the two mics 100% left and right eliminate the phase issue entirely at least when it comes to comb filtering?
Greg, that is highly appreciated. I will play around with it first thing in the morning as I have the day off tomorrow. Awesome!
(Although I suspect you just needed a good excuse for posting yet another picture of your rig. Which is cool)
The rule of thumb is, closer to the edge more bottom, closer to the centre more tops, so I start about halfway.
This is how I miked my guitarists amp when we recorded the last album, all close kicked as we played the tracks live, guitar, bass and drums.
There is a fathead ribbon, a sennheiser ME20 omni pencil condenser and a Sennheiser 421. The 421 sometimes was swapped out to a sm57 depending on the track. All mics going to separate tracks on the recording.
Alan.
Nice rack of basses there Alan...![]()
i have the at4050, which is pretty much flat until 9khz, sitting about a foot and a half in front
a 57 jammed in the grille pretty close to the edge of the speaker
mixing in the 57 dependent on how much meat i want
sounds pretty awesome
phasing starts when i pull the shure out a couple inches
just using one or 2 57's didnt do it for me. colored the sound way too much
'Phasing' you didn't like
Sorry to keep hitting on this.. but it is true![]()
what?
With this spacing there is already phase interaction. What you heard wasn't the difference between being in phase or not, it was the difference between phase shift you liked and phase shift you didn't like.
mic 2 is a foot and a half from speaker.
mic 1 is a few inches away
i had assumed that i was breaking the 3:1 rule when pulling mic 1 out an inch or 2, because thats when i started hearing phase.
well, like most things in life, you dont need to fully understand "why" something "is" to appreciate "what" it "is"
True that- you don’t have to have ‘the rules, or ‘science’ of it.The 3:1 rule doesn't apply to a single source, it applies to multiple mics on multiple sources where you want to minimize bleed.
For a single source just use your ears and position things to sound good to you.
To cover again as it's a useful bit to get driven home- The only place where ‘two’ can be 'in phase’, is equal distance/equal time.
So the bottom line is for any 'second mic’ your choices are any position where your out of phase at some frequencies (in phase at others) tone -- make for pleasant useful combinations when blended together.
You can also have the case were one position makes for a very good tone picture (on its own), but the combined times don’t. Then the option is to adjust their relative times so they do work blended.
Another bit that might be helpful is the -9 dB rule;
The combined phase effect of any second signal attenuated by about that much are no longer oblivious- therefore making them not a problem.
In these ‘near + far mic’ questions this is often mistakenly applied / referred to / AKA as “The 3:1 Rule”.
