mca sp1
  • Thread starter Thread starter StudioMxpx
They're the same thing as the Marshall MXL-990. Which is basically an mxl-603 (small diaphragm) in a large body.
Good for some things; not so good for others. They definitely have nice high end clarity, and quite detailed. Not very full-bodied, unfortunately, but Jim Williams at Audio Upgrades can fix that for a hundred bucks or so if you ever feel like sending it off for modification.
It has the potential to be a really excellent mic.
yeah im going to use it for overheads and vocals. can i get more info about the modifcations?
Most people consider 20mm to be small diaphram, although it is in the large range of small diaphram. Most Large Diaphram condersers are 25mm.
Just because a microphone is side-address does not make it large diameter.
Yea, Jim Williams is kind of an interesting guy. He's a technical whiz who spends most of his time tweaking stuff to make it sound better. I suppose that sort of thing has always been common / popular with guitar amps, for instance.
But basically, Jim has sort of a list of cheap gear that he's figured out how to swap a few things out -- a cap here, a chip there, maybe a few other things, and suddenly you've got a noticeably better-sounding piece of gear.
I think it's a great service, so I try and support the guy whenever I can by way of word of mouth on these boards. Jim is good for the audio community, in my humblest of opinions. I really respect the guy and his work.
www.audioupgrades.com
As for these mics, I really think they have a lot of potential. It seems as though it's got a great capsule (same as the mxl 603 which happens to be a pretty nice and detailed mic), but that it suffers a bit in that some of the electronics leave something to be desired, which is where Jim comes in to work his magic.
As for the capsule size, I wouldn't let that effect anything. Medium diaphragm condensers tend to work just fine for vocals . . . and they're extremely versatile.
