D
Dot
The VoxBox does what it does and does it well. Though I think the comp section is better than the mic pre section. I might recommend it if I was sure it would solve your problem - but it probably won't. Karyn, I think it's a mistake to be looking at channel strips over $3000 as a fix for a mic sound you don't like. If you're getting a harsh sound you should also be looking into the kind of converters you're using and also the acoustics in your room. I'd also consider looking into other mics.
Instead of a VoxBox or any channel strip, you might consider a good pre and a good compressor separately.
