Tekker
I'm having a serious problem with my computer right now and I have absolutely no idea what is causing it. I just opened one of the projects I’m working on in my recording program (Magix Samplitude) that has every track "frozen" (where each track is mixed down to a wave file and all of the real-time effects are removed to reduce most of the load on your CPU) and when I try to play it the CPU indicator in Samplitude goes up to around 188%, the playback skips repeatedly, and it won't play the project. So then I created a new project and loaded in only “one” wave file, and when playing it back the CPU is at 0% with occasional spikes of 27%-36%, but it skips each time one of those spikes occurs. So basically my computer can’t even playback a single track now.
Here's a little background as to when my problems started:
I got some new computer components (new motherboard, processor, and RAM) not to long ago and everything ran excellent for about a month..... Then one of my brand new RAM modules died causing my computer to reboot on its own during even the smallest tasks. When I removed it (leaving the other “good” one) my computer was running horridly (couldn't use Samplitude at all due major stuttering problems mentioned above) and I was told on the PC perspective forum that the bad RAM may have corrupted the installation of windows so that's what I figured was wrong with it.
I sent my bad RAM module back to Corsair and received the replacement. Then after I installed it I reformatted my C drive and reloaded windows..... But after all of that, I'm still having the same problem in Samplitude as I was before, right after I removed the bad RAM module. The skipping problems I mentioned above were all after I just reloaded windows XP and everything, so I don’t know why it’s not working.
I ran a RAM checker on both RAM modules (in the off chance that the new one was also bad) and they both passed with flying colors. I also tried opening up the Task Manager while playing something in Samplitude and according to it, Samplitude is using up 99% of the CPU. I started out using the default buffer settings and have tried MME and ASIO drivers both giving the same results, I have never had to tweak the buffer settings before so I'm quite positive this is not the cause of the problem (but just to check, I did increase the number of buffers from 4 to 8 and no change).
I have never (ever) had problems like this before, I tried running the SAWStudio demo and had the same exact problem (even with one track) and SAW is a very CPU efficient program.... So something is still seriously wrong with my computer and I’m out of ideas to try at this point.
Here are the specs to my PC:
Processor: AMD Athlon XP2800+ Barton
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80177-R
Motherboard: Asus A7N8XE Deluxe Socket A Motherboard
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=240314
Memory: (2x) - Corsair VS1GB300C3 ValueSelect 1GB DDR SDRAM
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80098-34
Windows XP Professional
Recording Stuff:
Samplitude Professional 8.2
Aardvark Q10 (with the newer 7.13 driver)
Also, if this helps, here are the temperature and voltage readings from the BIOS.
MB Temperature: 24C / 75F
CPU Temperature: 52C / 125F
VCORE Voltage: 1.66V
+3.3V Voltage: 3.29V
+5V Voltage: 4.83V
+12V = 12.28V
If anyone can help solve this problem I would be eternally grateful!
-tkr
Recording Stuff:
+5V Voltage: 4.83V
+12V = 12.28V
-tkr
