Maintaining constant humidity for guitars
cellardweller
cellardweller
Haven't noticed Light around for a while, originally it was he that I heard about the importance of maintaining humidity (especially in dry winter months) for guitars and wood instruments in general.
So how about it? What is an allowable variance day-to-day? month-to-month?
Also, does anyone know the name of the product which you put in your guitar/whathaveyou case to maintain humidity in the case?
The humidity here in Illinois was down to 20% one day, raining the next. My guitars are in a room with a humidifier, and in the next room is a dehumidifier, so it's pretty safe (I think) in the "cellar", but lately I've been recording in other areas of the house...
A humidifier. Thats the name youre looking for:)
But really. I have a hygromoter in my studio room where I also keep my guitars, and I have a case hygromoter in with my Taylor, too. I keep the room between 40 and 50%...I know the Taylor factory says optimum is 47% and thats as close as I can reasonably keep things. I used to use a Damp-It, but I have found a damp sponge in a couple of Ziplock bags opened does just a good job, or better, and I dont have to fill it up every 2 days.
Taylor has lots of good articles on humidity in their tech sheets:
http://www.taylorguitars.com/guitars/reference/techsheets.html
Just always keeping it in the case is probably the most important thing.
H2H
For stable, constant humidity and protection, I keep my guitars in a modified "guitar cabinet" that I made. I bought a 'Robin' storage cabinet from Ikea that was meant to store clothing. I installed a custom, home-made lower bracket system and used foam pipe insulation over the steel brackets to rest the guitars on a cushioned surface. Then I used those u-brackets that are supposed to hang up rakes and brooms on your garage wall on the back wall of the cabinet (mounted into a 2 X 4 piece of wood).
I made some mini humidifiers from those cheap plastic food-storage containers you buy at the grocery store. I bought some anti-microbal sponges and cut-to-fit them inside the storage containers. Then I drilled several large holes in the lids of the storage containers, fill the containers and popped the lids on 'em. I fill these containers with distilled water about once a month and put a cheapo hygrometer at the bottom of the cabinet to monitor the humidity, which always stays at 68% all the time.
Total cost of everything is about $175. The cabinet was only $99 itself, the rest was the other stuff I described. The cabinet will hold up to eight electrics and also has small storage areas up top for effects, straps, etc. Mine is set up for seven electric guitars and one acoustic. I also have a smaller cabinet that holds my other three guitars, which is basically the same set-up, only smaller. I installed some lights in the cabinet, too... also from Ikea.
Here's what it looks like (minus a couple guitars I took out to clean and polish). Sorry if the pics ain't that good, but you'll get the idea of where I'm coming from...
Guitar cabinet in the daylight:
Guitar cabinet with interior lights on: (..the little tiangular-shaped thing is my hygometer)
Bottom brackets with pipe insulation and "humidifiers":
Rubber-coated garden tool holders as "neck rests":
I decided to make this cabinet for four reasons...
1: It has doors that I can lock with one of those plastic "baby locks", which keeps my 4-year-old and one-year-old boys from messing with my guitars.
2: I play more often because it's easier to reach into the cabinet and immediately pull out the guitar I want, rather than sift through a big pile of cases and gig bags.
3: My guitars stay preserved at constant humidity and temperature levels of 68% and 72 degrees farenheit.
4: My guitars stay clean and dust-free in the cabinet, since they're not sitting out on stands.
I know it's not perfect, but it does the job for me! :)
Excellent idea...
I have one of those cabinets in my garage now not being used. Guess what I am doing this weekend...
Thanks Buck...
Seriously - "not perfect" doesn't matter when it is very functional and gets the job done.
I, for one, am impressed =)
I live in one of the dryest and hottest places on the planet and have found out the hard way about lack of humidity, I find that a soap dish with holes in it and a well soaked sponge topped up once a week is pretty amazing in avoiding any further problems. Absolutely basic but it works.
Today is winter which lasts 3 months and temp will be around 32oC (89oF) and for most of the year average 45oC (113oF) so that is pretty hard on an instrument if you are not careful. Try a sponge they're cheap.
In Illinois, you are probably in the same general class as we are here in Minnesota. A Kyser Lifeguard and a soap dish humidifier should be used anytime you have the heat on in your house, and of course you should keep your guitars in the case when you are not using them.
Even when the summer humidity falls, it is not a big deal, for two reasons. First, it is not for very long, and second, 20% humidity in the summer is equivalent to probably 40-60% in the winter. If you think back to high school physics classes, warm air holds a lot more moisture than cold air, and it is relative humidity.
Don't worry about while you are playing them, either. They will seldom be out of the cases long enough for it to be a problem.
Light
"Cowards can never be moral."
M.K. Gandhi
Right now I just moved my studio to the basement of my house...first problem I had was it was cold...no heat down there...temperature stayed around 60 if no one was down there....second problem was when it rained the humidity jumped to about 75%...i solved both theses problems by sticking a dehumidifier in the room that kept the humidity around 55% and heated the room up to 72 degrees....i guess ill have to wait and see what the winter brings...!! Right now im using two digital humidity readers and i notice they tend to vary a bit maybe like 2%...are they accurate enough? Do i need hydrometer? How do they work?
My cabinet
I made the Buck62 special guitar locker. My axes have never been happier..
Thanks Buck!!!
Thanks Buck!!!
WOW!!
That looks great! :)
Don't forget about the mini-humidifiers... those precious babies need some moist air to keep them at peak performance!
