bouldersoundguy
Power ratings are always referred to some percent of harmonic distortion. Most power amps will put out quite a bit more than their rated power with more distortion, at least until they overheat. I suppose you could just run it up until you see the waveform start to flat top for an approximation. Also, music is different from sine waves. What an amp does at 1kHz doesn't say a lot about what it does at the lower extremes of the audio spectrum. What kind of test signal are you using?
