ibleedburgundy
The Anti-Lambo
I have a Mackie 1400i amplifier that I would like to use for a PA. It's actually for my second PA because my band has two practice spaces. I am trying to cobble together a "B" PA using stuff I already have except for speakers. I am planning to run a Mackie 1604 vlz into the 1400i. Mostly keyboards and Vocals but I usually like to add a little bass drum and bass guitar as well. This is for a 5 piece band - drums, 2 guitars, bass guitar, keys, some vocals. We play alternative/blues etc.
So in the owner's manual it talks about the different configurations you can run the amp in - stereo, dual mono, and bridge.
Bridge mode:
max power of 1400 watts into 4 ohms
max power of 1000 watts into 8 ohms
continuous average output power of 1260 watts into 4 ohms
continuous average output power of 850 watts into 8 ohms
Dual Mono or Stereo Mode:
max power of 500 watts into 4 ohms
max power of 300 watts into 8 ohms
continuous average output power of 425 watts into 4 ohms
continuous average output power of 250 watts into 8 ohms
http://www.mackie.com/pdf/m1400_m1400i_om.pdf
I want to optimize the speaker selection for maximum loudness. Stereo capeability is not a must, but a nice to have. If running 1 speaker cab in bridge mode gives by far the most volume at the expense of stereo, I am OK with that.
I have a few questions: If I buy 4 ohm speakers instead of 8 ohm speakers, will they generally be louder? Does anyone know which speakers would be optimal for this amp? The mackie guy of course recomended some Mackie speakers - 300 watt 8 ohm mackie passive 12 inch PA speakers. Would these speakers have less volume than other options?
Bridge mode:
