M-audio Octane design flaw
  • Thread starter Thread starter drumvan
D
drumvan
I thought I would post this report due to the large number of people that ask this and other forums about which 8 channel pre-amps they should purchase.
I recently bought an M-audio Octane unit for recording drum tracks in my home studio. I use the adat lightpipe to connect to my Protools 6.4 le system. My mic setup consists of the following:
kick - Audix D6
snare and toms - SM57's
overheads - (2) Marshall MXL 2003's
hi hat - Rode NT-1A
I discovered almost immediately that when plugging my overhead condenser mics onto channels 7&8 with phantom power engaged, that a fairly loud buzzing and humming noise came up. The noise slowly faded away after about 10-15 min. I switched chords, outlets, ground scenarios etc. and it still happened after a cold start. The weird thing was that if I engaged the -20 db pad on channels 7&8 the buzz went away, even with the gain all the way up. M-audio sent me a 2nd unit to try to see if the unit was defective. Same results with the 2nd unit.
I took the Octane to a local high end recording studio to check it with other mics, cables and power supply. Same results with my mics (Marshall's & Rode) but when some Neumann U87's were used, no buzz. We started trying some other mics with different ohm ratings (ADK-A51's, Oktava mk012's, Shure KSM-141's). Bottom line, any mic less than 200 ohms caused channels 7&8 to buzz. I informed M-audio's tech support of this and they did their own testing of the Octane units at their factory with various mics. Sure enough, they have admitted to me that it is a design flaw.
So, if you have an M-audio octane or are looking to buy an Octane be careful about the condensers you use. Anything less than 200 ohms will more than likely cause you a very annoying buzz or a 15 min. warm up time for the noise to go away.
Hope this post helps someone. It cost me a lot of time, headaches and some $$ to ship one of my Octane units back to the factory. Worse yet, M-audio didn't even say thanks for finding the flaw or offer any thoughts as to if the problem would get worse over time. Go figure. :mad:
Van
I read your post on this and another forum. Thanks for the heads up. M-Audio should give you something, a cookie, a pat on the ass, a pre-amp...something.
6
Thanks for your post, very interesting. I use my Octane for drums, too, but I only use channels 1-5 (kick, snare, 3 toms, don't need a hi-hat mic). I'm using a pair of MXL 603s and a DMP3 for the overheads (because I had gotten the DMP3 first and already like it for overheads - if it ain't broke, don't fix it...).
I do use 7&8 on the Octane for M/S stuff, though, and haven't had any problems with it. I'm using the analog outs, though, so that may be a factor.
octane
hey mad,
just as a test try your 603's in 7 & 8. they have a 150 ohm rating like my 2003's. power up from a cold start. engage the phantom power for 7 & 8. no -20 pad. turn up the volume or headphones and see what you hear.
i totally bypassed any outs when i was testing mine. stuck a pair of headphones right into channel 8's output. hummmmm/buzzzz.
let me know what you find out. maybe they've gotten a bad ship of electronics from somewhere lately or maybe it's always had that problem. mines about a month old.
van
drumvan said:
hey mad,
van
I was thinking of trying it anyway, so will do! I'll let you know what happens. I've had mine almost a year, BTW.
15 minutes to warm up huh? What in there could possibly take 15 minutes to warm up? Hmmmm :confused:
i know punkin, it's strange. also mics that have lower impedance, like the rode nt-1a (100 ohms) take longer for the noise to go away (25-30 min.). the marshalls which are 150 ohms take 10-15 min. the key though is to have both channels 7&8 occupied by condensers with the phantom power on. just 1 mic won't do it alone.
the adk a51's i tested only buzzed for a couple min. the adk website does not list the impedance rating but i'm guessing it's just shy of 200. maybe 175 or so.
van
Strange...
I've been using my Octane specifically for over a year now and I've never encountered this hum/buz problem. I use all eight channels at the same time, including the M-S encoder section of channels 7 and 8. The mics I'm using for the M-S channels are a Studio Projects B3 for the figure eight mic and a B1 for the single pattern mic. Gorgeous drum tracks every time.
klash,
could be because the b1 & b3 is spec'd at <200 ohms. this could mean it's just slightly above the impedance that caused the buzzing in my unit. like i said, the adk a-51's buzzed for only a very short amount of time. somewhere between 150 & 200 ohms appears to be the "magic number". if the b3's would have been listed at 150 ohms i would think that maybe they got a bad batch of electronics in and you got lucky. the thing is, their tech dept. admitted that it is a design flaw issue. :confused:
hey, when the Octane warms up it sounds great. i can live with it if it doesn't get worse as the months/years go by and the warranty expires.
van
hey mad audio,
did you try testing your marshall mics on 7 & 8? results?
van
