looping
  • Thread starter Thread starter jazzyblues
J
jazzyblues
I use Sonar and have some drum loops I want to use but can't figure out how to loop. I know how to import the loop onto the track, but once there I don't know how to loop it. I tried copying and pasting, but that didn't work out very well.
I really would appreciate someone explaining how to loop drums.
thanks -
Best effort shot dude.
Look at the the bar above the tracks there should be 2 little flags up there set one to the the begining of the imported track and the other at the end of the imported track.
There should be a loop button somewhere near the play button on the transprt bar.
It may not be looping correctly or match the tempo that you are trying to use so you may want to do a little time streching on that loop.
If all else fails pick up the manual it explains how to do this clearly in there.
Thanks. Unfortunately, I no longer have the manual. That's why I'm asking here.
CtrlC, CtrlV
Copy, paste, should work fine if you have a good loop length.
