Loop Pedal and multiple sounds with audio interface
  • Thread starter Thread starter Iceheart
[MENTION=198857]Iceheart[/MENTION] I don’t use a looper, Podfarm or Cubase so excuse this intrusion but are recording to a click? That would make looping a single take in the DAW pretty easy.
ashcat_lt I see.
I use Podfarm 2.5, the program. Not Cubase plugin, does it matter?
The PodFarm standalone has some routing options which probably make it possible, but I always use the plugin version and the routing capabilities of my DAW.
The main point is that you want your guitar going into one input, through whatever effects/amp is set up in PodFarm, then back out to the looper, then if you want to record what's coming out of the looper, it needs to go back into the computer, but not be routed back to the same output because that'll cause feedback.
I understand now, I just need Guitar -> effect -> toneport -> amp/podfarm etc.
The question now because I'm a newbie to this kind of stuff... How do I do it exactly? With UX2, Boss RC-30.
