looking for recording program
  • Thread starter Thread starter ESPplayer7
E
ESPplayer7
im looking for a freeware recording program that i can record a rhythm to and play it back as im recording the solo ontop of it. Ive tried audacity which is pretty good but i cant seem to hear the rhythm when i record again. THanks everyone
Audacity should work. You just need to arm a separate track for the solo (meaning, the software doesn't mix them together -- you'll have to mix them after recording).
Other freebies:
Kristal Audio Engine
Reaper
http://www.digitalsoundplanet.com/SoftwareHouse/Products/Audio_Master/Freeware/freeware.phtml
Quartz AudioMaster Freeware, as its name suggests, is FREE ! It's the best way to try the Quartz Audio Family software concept. It includes the minimum, but yet powerful, features to start things for real and possibly share projects with people who own one of the Quartz AudioMaster commercial version. Quartz AudioMaster Freeware will allow you to record, edit, mix, share and deliver your productions driving a fully integrated 4 tracks digital mixer, recorder, sound and time line editor in perfect synch with a 16 tracks MIDI sequencer.
Easily record audio, in perfect sync with Midi, with any instrument or microphone or assemble already existing audio materials or music loops. Easily record Midi, as well, using a Midi keyboard or your computer keyboard and even if you are not a professional musician don't get stuck by difficult parts to perform, thanks to the genuine 'Scale filtering' feature. A tutorial will help you getting started quickly.
Then cut, copy, paste, move, repeat your audio elements and Midi elements and mix your tracks applying real-time DirectX or Quartz plug-in effects on audio.
Need to fully edit GS or XG synths, everything's there, just do it !
Want to work with remote musicians? The genuine Quartz Audio multi-track compressed file format and our virtual studios will allow you to share your projects through the internet...
When everything's finished, print your Score and/or easily and mixdown to standard stereo files using many formats including MP3 and publish it on internet !
Audio Technical Specifications :
Runs on Windows™ 95/98/ME/NT/2000
4 audio tracks
1 Audio Inputs (2 channels)
1 Audio Ouputs (2 channels)
16/24 bits / 32->44.1 Khz sample rate
2 Aux Buses
Quartz Plug-in Support
4 Quartz Plug-ins supplied
* Stereo Delay
* Chorus
* Phaser
* Reverb
MIDI Technical Specifications :
* 16 Midi Tracks
* 1 Midi Input
* 1 Midi Outputs
* 48->96 ppqn
Minimum System Requirements :
Minimum: Pentium 166Mhz, 32 MB RAM
Recommended: Pentium 300 MHz, 64 MB RAM
256 Colors or greater required (600 X 800); 24 bit color recommended.
Windows-compatible sound card required.
Simultaneous Playback and recording depends of sound card used.
