DM60
Looking for recommendations or guidance on a 4 channel mic pre-amp.
Here is the intended use, mainly drum mics (Kick, Toms, Snare) going into Tascam 1800. When I record live, everything is going through microphones. Since I am using 7 microphones on the drums, I am actually using all 16 inputs to the Tascam. I have been looking at the Nady but I am a little reluctant to purchase this unit. I don't need the 8, but I just won't use 4. Hoping to get 1/4 and XLR inputs (dual input).
What I ones have found to date are either really low end or up in the 1K+ range. Maybe if I get good enough I can start to think about upgrading, but right now, trying to keep my addiction manageable. Wanting to stay under $200. Hopefully I have provided enough information. Any guidance is greatly appreciated.
) I have a Mackie version of this mixer, plus I wanted to keep the channels separate.
The switch on the inputs (+4/-10) looks to do the opposite of what I thought. I had it on +4 and pretty much killed the incoming signal. I should have set it for -10. I tested this and the signal was much better. I was thinking for a drum mic gain wouldn't be needed, I think this is still correct now I have tested it. So I will try another session without the preamp.
