mark4man
MoonMix Studios
HELLO AGAIN (after many, many years)...
Don't know if u guys remember me...been using Cakewalk music creation software since Pro Audio 7. The old SONAR Forum at Cakewalk is a real mess (or non-existent)...can't get in.
So: I created my own SNARE samples...from a ROGERS PowerTone 5" (circa mid-'60's) & a TAMA RockStar 6" Stainless Steel (circa mid-'80's...I believe). I recorded these samples using both overhead & underside micing, in my studio, w/ great mics & a great preamp (w/ an Aurora 8 AD/DA)...under pristine conditions...into SONAR Producer X1.
1) MIDI MAPPING: I know what notes to assign for 'standard snare hit' and 'rim shot' (believing rim shot to be the same note as electric snare).
2) VELOCITY: I've noticed in every Drum Sampler I've used (Session Drummer in SONAR primarily, these days)...there seems to be 3 different snare hit sounds...a light, medium and heavy velocity, w/ medium kicking in at 50 & heavy kicking in at 100 (correct me if I'm wrong). So...I recorded my samples at 3 different stick hit levels, low, medium and high (hoping I'm on the right track here?)
3) SONAR used to have 'widgets' I believe, for creating one's own sample-based software apps...so my questions are:
A) Should I use a widget & create my own Snare Sample-based App in SONAR...& if so...where can I find instructions on doing so in Producer X1 (or elsewhere)? (instructions that would explain every detail of not only creating the app, but also audio clip assignment relative to mapping & velocity). (actually...NTITAI...don't remember seeing widgets anywhere in SONAR...remembering these from PA9).
B) Can I add my snare audio clips to an existing drum sample library (example, Session Drummer); & then make my mapping and velocity assignments within that app?
Thanx...need some direction here...remember reading the basics of widget app creation way back when, but never implemented anything.
mark4man
mark4man
