I assume CLASP is nice for those searching for a tape sound but preferring the workflow of a DAW. I'm not amongst those.
However I'd love if someone made it possible to use a DAW as a remote for a tape recorder for editing and muting tracks without any AD/DA conversions being made and staying out of the box. To do spot erasing from a screen would be great.
DAW workflow is just different....but not better or worse.
I started out with the G16...well, I actually started out with tape long before that, on a 4-track...but my more "formal" studio rig was with the G16. I already had computers for MIDI sequencing, but soon after added one for digital audio.
That's when I "saw the light".....
...and came to the conclusion that a hybrid approach was the best of both worlds.
You will NEVER be able to do spot-edits on tape like you can in the DAW, and for me THAT is THE #1 purpose of a DAW.
Sure, these days they've become the complete "studio" for many folks, and that's fine....but it's the editing/comping power that most pre-DAW tape users were missing and wishing for.
There's this notion some people have that "pro" recording is all about nailing the perfect take....not so. There was from the beginning and even more-so today, a lot of editing going on in pro studios. In the early days of tape recording, they HAD to try and nail it in one take because of the lack of any editing options. Then came tape bouncing, and of course, splicing with razor blades from different takes to create comps.
The DAW makes all of that look silly and almost caveman-like...so if you track with analog gear to tape, then dump to DAW and do your edits, comps and whatever you desire, then come back out of the DAW and mix through a console with outboard analog gear......that to me is as good as it gets.
Some people will stop short of coming back out of the DAW once they dump in the tape tracks, and they mix in the DAW...and I'm not as against that as I use to be, because the DAW tools have improved and mixing ITB can work, plus you have that bonus of instant recall....but in my own case, I still like coming back out and mixing analog.
AFA your question about a using a computer as
a remote....I was doing that with my G16 back in 1990, using an Atari computer running
the original Cubase MIDI sequencing program. The folks at Steinberg wrote the code for a G16 driver for Cubase that allowed you to lock the two together, AND you could actually arm and initiate recording from Cubase and set punch in/out points, and the G16 would perform them flawlessly.
I use to just hit REC/PLAY/FF/RW on my computer keyboard...and the G16 would follow.
I still have a couple of Atari computers and the Cubase program and peripherals, but I took it out of service several years back, since now I do all my DAW/MIDI work with
Samplitude out of a PC, and that too was/is locked to the G16 via SMPTE/MIDI (though it can't arm tracks or command punch in/out on the G16, though most DAWs provide machine control, it's just a matter of having the right drivers. With something like the G16, it's been out of production for so long, none of the current DAWs would bother with it.
These days I'm only using my Otari MX-80 to track to, and I've semi-retired the G16, but it's still all hooked up and I could track to it if needed. I may sell it off at some point, since I hate to see it not getting used....but not just yet.
