Logic Platinum Wont run
  • Thread starter Thread starter christos
C
christos
I am trying to use Logic platinum 5.2 (for the first time) but i cannot get any sound at all.
It wont record it wont even play the demo files.
It is running but NO SOUND.
All my other programs run ........no sound problems at all.
Am i missing something i have to enable in Logic?
First of all, which version, PC or Mac ?
Second, What soundcard ?
Did you go to the driver page setup within Logic and assign the right drivers in the flip down menu's ? You have to manually selec t the appropriate drivers for the card you have amongst other setup issues.
goto
preferences \ audio hardware & drivers
choose a driver for pc av and check the pc av box .. relaunch logic and you'll be fine
goto
miuhuru said:
goto
What the heck is going on here
i go to preferences \ audio hardware & drivers it dosent show me any drivers AT ALL to choose from
it says "no driver" at the spot where i have to choose a driver from
PC the card i have on this machine ia a vortex audio card
i do go to that page there isnt any driver at all for me to choose from
Strange program All other recording programs run fine lol
Check the box for PC/AV only. Hold your mouse over the driver box and right click on it. This should show the current card you have in a flip down menu. Highlight it. Uncheck any and all other driver boxes such as ASIO, etc..
I check box PC/AV only I hold mouse over the driver box which says "no driver" i highlighted right click on it but nothing happens.
There is no sroll down menu at all........
Should i uninstall reinstall and try again?
try this..
in logic audio folder there's a executable
easimme.exe
run it and check if there's a soundcard .. try rescan or smth.
after that if there's anything try the 'no driver' beside pc av dropdown menu..
..or just reinstall and remembr to check only pc av in preferences
other checkboxes are unchecked by default
hehe .. reminds me the time i was first launching logic audio..
after 2 days of confusion and hard brain work .. i got finally a sound out of it :))
miuhuru said:
try this..
easimme.exe
He he..... Glad to see that im not the only one confused about this
program.
I will do all the above that you mentioned and will let you know
how it went
I was just about to delete it and throw it out actualy LOL
Once you get it going, I can assure you Logic is a great and stable program.
It sounds like Logic cannot find the card in your system because it should have showed up in the flipdown. What is the driver this card is using ? MME, ASIO or other
It has 2 listed
EASI Direct sound and EASI MME
Dont sound too good does it lol
christos said:
It has 2 listed
I cant look right now because my Logic is on my other boot, but perhaps you need to check the box for MME or EASI rather than PC/AV and then search for the card in the flipdown
i uninstalled and reinstalled
chose mme direct sound and theres sound coming through now
AT LAST!!!!
By the way
what is easi direct or easi mme ?
That is all the options i have there.
