brownbearTLE
Hi everyone,
I wasn't sure where to post this so i figured i'd start here.
Anyway, i've had logic express for over a year now (including my interface) and everything was working fine. But recently, it disconnects from my presonus fp10 when adding impulses.
Whether its adding different impulse files to the LAconvertor, adding an audio file to the arrange window, or adding ANY external file from my computer into logic, the audio ceases (every meter including the master bus drops to zero).
To fix this i have to go to preferences, then audio, then switch from my presonus to built in output, then switch back to the presonus to make it work.
i usually have 4 guitar tracks to trifle through hundreds of redwirez impuses to pick the perfect one, and to pick that special reverb for the masterbus, effects, vocals, ect.. And you can imagine this is very time consuming and VERY frustrating.
Ps, i have the highest buffer size, the cpu never peaks, and the HD sits about 1/4 of the way on a busy mix.
If anyone has had this problem, do you know how to fix it?
Thanks
Thanks
