D
		dreib
Active member
I only have a few options for mics, a 57, or a cheap pencil condensor, 991 I think, but where is the best place to put the mic?
Thanks!
			Thanks!
Just live performance.
			man .... upright is tough for live. You'd be FAR better off is you can get your hands on a contact pickup you can stick on the bridge ..... there are some pretty cheap ones.Just live performance.
			ALL the pro upright players I've played with including a couple of VERY good ones (one in Orlando that I think might be the best upright player ever) used pickups that are installed into the bridge.I used to play upright for a living. Been through dozens of mics and other gear.
A dynamic mic is better than a condenser *except* for the DPA 4099. That is a miniature shotgun and works awesome. I think I paid about $500, but well worth it. Great for recording too.
Another option to increase your gain before feedback is to use a small Reflexion filter. A 57 in one of those would work well.
Contact mics / piezo pick ups sound like arse. Avoid them if possible. If you cannot get enough gain before feedback with just a mic, your options are to blend a pick up into the mic sound for the extra gain, or switch to a magnetic pickup. A magnetic pickup will make it sound more like a fretless electric, but you will have tons of gain before feedback. At that volume, you're going to lose all the nuance of the instrument anyway - so sounding just like an upright is probably not the priority. Piezo pickups will feedback too, long before a magnetic pickup. I've used this one: Stringcharger.com - Acoustical Bass Pick-Up
Finally, get to a high-end bass shop with your instrument and try some different cabinets. You might find one that compliments your bass more than others. Double basses all have personalities, and you really have to try stuff with your instrument. What is good for one may not be for another.
perhaps those aren't piezos?
I haven't seen a single upright player in years that didn't have something like that ..... none of them used a dynamic mic on the thing.
			You could try a AKG D112 down around the bridge
Alan.
No one's mentioned rolled up in a pad tucked in the tail piece.
I'd want some eq (1/3 oct or parametric if you can swing it) to tune it in some too.
			I would have but I was at work. There's also the padded 57 in an F-hole method.
If volume/bleed/feedback isn't too much of a problem then an RE15 often sounds fantastic on bass.
Way back in my early years of live sound I had some success with a pair of headphones clamped around the body. You put it at the bottom of the cutout opposite the player. Connected to a mono 1/4" input just the left ear cup is picked up so you can flip the phones around for two slightly different sounds.
Everyone gota have at least one of them no-proximity effect directionals around.If volume/bleed/feedback isn't too much of a problem then an RE15 often sounds fantastic on bass..
			Ok that's.. very interesting.
At the 'cut out. I guess the F hole for example might be boomy..
Damn I want to try this!
