Hey folks,
I'm about to make a live recording of a musical and at the same time will be mixing live. I'm using a Yamaha LS9-32 outfitted with 2 MY16AT expansion cards adding 32 channels of I/O. I will patch the additional outputs to the direct outputs of each channel thus outputting the consoles input channels directly to a 32 track recording.
The question is at what point in the LS9's signal chain should I tap for direct outputs. The options are Pre High pass filter, what is the earliest point in the chain, Pre eq - Post HPF, and Pre fader, which puts the tap point after the HPF, EQ, and 2 Comps and just before fader/ live mix.
Pre high pass filter sounds good to me because it is unaltered sound captured for later use. Yet it may not be the best idea. It is a live recording and a compressor for security makes me feel better about the possibility of clipping channels. And post EQ might help because we use countryman microphone elements and they generally need a bit of help and I'd hate to lay down a whole bunch of crap.
So I'm kind of at an impasse as to what to do. All the options have a trade off and none of them are perfect so what are your thoughts?
