G
Weak....Ginuwine said:you can buy the beat from me if you want then you can spit over it.
jake-owa said:Weak....
Your beats aren't worth a penny. A collaboration however is worth more than money.
jake-owa said:Well you could start by making some original sound effects to add in there. Your rythyms are mostly made of some generic type stock sounds. It gets old. When I hear a beat and the sample names appear in my mind I get really bored.
Get a cool synth and make some custom settings.
Make a folder on your hard drive and start recording your own SFX. Use a mic and add real sounds in there. Take a car door shutting and slow it down in sound forge and use it every other snare hit. Record a real wood block with your own self-customized filter or flange on it. Make your own kits of custom sounds.
Be original or "fresh" if that helps.
