drossfile
nope
ok, so after reading a million times about line level, faders to zero, signal to noise ratio, etc, i decided that my sound would get much better if i set things up properly. here's the deal: my akai dps12 has a gain knob for each input, marked "line" at lowest level, "mic" at highest. for years i've just used them as volume knobs (usually around the halfway mark), and today i turned the 2 inputs on the akai for my submixed drums all the way down (to "line" level). then i readjusted my mixer faders, decibel for decibel, so that the highest level is at zero. i'm running stereo channels out of the "control room" outputs on the mixer into the 2 panned inputs on the akai. i set my master volume faders (on the mixer) to zero, and then turned up the "control room" volume knob up until i was just shy of clipping my 12-track inputs. now, this should give me optimum signal-to-noise ratio, right? except the recording level is vastly LOWER now, and all my meters (on the recorder and mixer) are at the same level as before--just below clip! should i return to my previous setup? or should i rely more heavily on the mixer's built-in preamps' gain rather than the "control room" volume? i thought about going ahead and trying that, but if it won't help me, i don't want to get so far away from my original setup that i can't find my way back again. and while i'm on the subject, why is it that my mixer manual calls the pre volume knob a "gain" knob, but on the mixer itself it's marked "trim"? it seems that the more i learn, the dumber i get. it also seems that every time i'm content enough with my sound to leave it alone for a few weeks, i screw it all up by thinking it could be better if i only do this! or this! or this! crap!!!
