sjoko2 said:
			If you sample anything without prior permission you are liable, period.
Wrong.
Let me provide some info:
A copyrighted work may be used under certain circumstances under the doctrine of "fair use" of the work.
"Fair use" means that brief portions of published materials may be copied, but the law does not state the exact percentage of the total publication that can be used.   "Fair use" is pretty much just that; writers should use published material to illustrate their own points but not to substitute for the original work.
The act states that fair use of a copyrighted work, "for purposes such as criticism, comment, news reporting, teaching (including multiple copies for classroom use), scholarship, or research, is not an infringement on copyright."
Unfortunately, there is no set formula for "fair use" because the doctrine is an equitable rule of reason.
However, the Copyright Act notes that the courts have evolved a set of criteria for fair use, which although neither definitive nor determinative, provide some gauge for balancing inequities. These include:
- the purpose and character of the use, including whether such use is of a commercial nature or is for nonprofit educational purposes;
- the nature of the copyrighted work;
- the amount and substantiality of the portion used in relation to - the copyrighted work as a whole; and
- the effect of the use upon the potential market for or value of the copyrighted work.
Most importantly:
The Copyright Office at the Library of Congress has a hotline for dealing with such specific questions. Call the Copyright Public Information Office at (202) 707-3000 for more information.
Note:  This is not intended to be legal advice.  Most of it is either musings of paraphrased or directly quoted from http://www.virginia.edu/~urelat/Guide/PartII-9.html  If you have actual concerns about potential copyright infringment, please consult an attorney.  Make sure your wash behind your ears.  This message has not been evaluated by the Food and Drug Administration.  The advise in this message is not intended to diagnose, treat, cure, or prevent any disease.  For best taste, consume this message by January 19, 2004.
-B
