C
chessrock
Banned
Here's a hypothetical scenario:
Suppose someone comes to you for a small recording project.
Their plan, ultimately, is to distribute 100 CDs.
When the project is done, you give them 2 copies: One is an audio copy clearly labeled "Audio," while the other one is a data CD, with the 16-bit .wav file, appropriately labeled "data."
You tell them briefly the difference between the two, and that they will want to take the data copy to wherever it is they are having it burned.
Two weeks later, you get a call from the client, telling you they got their CDs back from whoever burned the copies for them. But there's one problem: They put the CD in, and there's no sound. Nothing. You tell the client to bring it up on their computer and see if there might be a .wav file there. Sure enough, there is.
So basically, the CD house just burned them 100 copies of their .wav files.
Anyway, the client now wants you to reimburse them for half of the expense to have them re-burned. Their logic / reasoning is that you didn't clearly explain to them the difference between the audio CD and the data file CD. That you should have explained to them that the data CD will not play audio on a standard CD player, etc. Not to mention the fact that you told them to bring the data CD to whomever would be burning it for them.
So my question is . . . what do you do?
And more importantly, what do you do to cover yourself from future problems like this? Do you have a legal document for them to sign that clearly spells out that your job is to record, and mix the audio, etc. and that any problems that occur further down the line are not your responsibility?
Keep in mind, now, that I'm dealing mostly with dipshits, so there are probably any number of problems like this that could occur, and I highly doubt I can anticipate every possible scenario, so I'm wondering if there's any sort of blanket contract that would cover my ass from anything that occurs once the project leaves my door.
Thanks!
Chessnubs
Thanks!
Chessnubs
