Latency....
  • Thread starter Thread starter memriloc
M
memriloc
Hi...Being very new to computer thing (I've always used 16trk analog) I need help....The computer I'm working on has a SB Audigy 2 soundcard and I'm aquiring a version of Cubase and mabey a version of Cakewalk....I've heard alot of people haveing trouble with latency...Do ou think I'll run into that?...If so what can be done about it?....Also, will I be able to sync my computer to my multitrack (Fostex G-16-S)...Cheers guys!
ANYONE PLEASE!!!....I wanna get some answers before I have to post this in another forum and get my hole kicked for mutiple posting :)
What driver are you using?
Use the ASIO driver for low latency, although this means you can use 48kHz only. The joys of using Creative Labs products :D
Cheers man....I've also read that I can just realight tracks after laying them, is that right?...So that should get me through until I save the dough for a Delta 1010 (which is what I'm doin')...And that should be better in reguards to latency yeah?
The Delta 1010 will let you set latency pretty low. I have a 1010. But how successful it will work depends on your computer. It might work fine right away. But if you get clicks and pops, you may need to tweak your system a bit.
In my case, I never cared about latency. I have it set really high. There are only a couple of ways in which latency matters. One is if you are going to monitor through Cubase. But since I monitor through my Mackie mixer, it’s not a problem for me. You can also monitor through the Delta 1010 to avoid latency issues.
Another place where it matters is in mixing. If you have a latency of 1 second, that means that every time you adjust a fader during playback, you will hear the resulting change 1 second later. Same goes for all knobs and faders. But in my case, I don’t mix in real time anyway. I use the editing tools to draw the fader automation. Then I play back, adjust, playback again, etc.
So if you work this way, I don’t think you ever need to worry about latency.
Ok...Mabey to put it more into perspective....
Computer is...
2.0GHz P4
256mb RAM
dual 60GB HDD's
Windows XP
As soon as I can I want to be able to sync the computer to my mutitrack, but for now it's just a matter of working out how to get things down properly on the computer....Timing IS an issue for me, I don't want to realy fuck around too much with outta sync timming asd such....That's another thing I need to know...What do I need to and how do I sync the two together?
Sorry, I'd answer except that I don't know anything about the Fostex machine or how to sync it. But I'd guess that if it can be synced, then Cubase SX can handle it. I don't know how tight the timing would be though.
Latency and sync are two separate issues.
Sorry, I know they're two different issues, I'm sorta trying to get two things answered while I"m on this thread....The Fostex is symply a 16 track analog machine...
as long as you're "acquiring" cubase legit you shouldn't have much trouble getting the latency down because you'll have the "Getting Into the Details" manual on disk to help you along...in short, open cubase, pull down the options menu and select "System..." from the Audio Setup submenu...this brings up the Audio System Setup dialog screen...here you will pull down the ASIO Device pop-up menu to show a list of available ASIO drivers...a dedicated ASIO driver for your SB card should be listed and you could select it, but make sure you take the time to download and install the latest greatest one for your SB card...however, if you have MS DirectX 8 or 9 already on your system, you may want to select the ASIO DirectX Full Duplex driver (assuming your SB card is Full Duplex capable and has drivers that support DirectX)...if the SB doesn't support DirectX you'll get an error message--in this case, go ahead and select the ASIO driver dedicated for your SB...once you made your selection a latency value in milliseconds will be listed...if this value is less than approximately 35ms your latency problems will be quite nominal if you are able to notice it at all...if you plan on monitoring through cubase you'll need to get the latency down to about 23ms for it not to be distracting...actually, I believe most human ears cannot even detect values around 23ms or less...if, however, you plan to monitor externally through your Fostex you won't have to worry about latency because cubase will compensate for the latency regardless...my advice would be for you to take advantage of your system's "FireWire" bus architecture by going out and buying a MOTU unit that will enable you to bypass your crappy SB and record digitally straight to disk...my MOTU 828 allows me to record up to 8 stereo pairs with excellent anolog to digital conversion...a fast pentium and a bit of tweaking under the Audio System Setup (Audio Performance)--"Memory per Channel" and "Disk Block Buffer Size" has cut my latency to as low as 7ms...I'm not very familiar with the Delta 1010, but I'll bet it doesn't allow up to 8 balanced stereo pairs to be recorded at once...a MOTU unit will also allow you to easily use your Fostex (and any of your favorite analog recordings) as a front end without using any of your "system" resources, and it won't be necessary to "sync" (master or slave) your Fostex to anything, although you could--if your Fostex has that capability...
one last thing--if you don't acquire cubase legit you won't have the "dongle"--which means you won't get very far.
SMPTE i believe is what it is called basicaly cubase will create a track on one channel of your fourtrack that acts as a click track sortof to keep them synchronized. if your fostex supports it ,it should work.
