_brian_
Member
Hi, I have a simple set up. The only preamp I use is a DAV BG1 along with an avalon U5 and these run into an RME interface which output to an Allen and Heath Zed10 mixer. It's a bit of a waste, but this is an easy control for speaker & headphone volume and it cut out the computer noise I was hearing when connecting my monitors and headphones directly to the soundcard.
Anyway, I got back into recording and thought I'd build myself a big mult-speaker cabinet loaded with different speakers, the build went well. I miked it up and trialled a recording.
I tried close and distant miking with an SM57 and SM57 Beta, this ran into the DAV BG1, but I could hear some excessive colouration. I was confused because the preamp wasn't peaking and I know the BG1 should be transparent, the RME software wasn't peaking and cubase wasn't peaking.
I heard this colouration through the speakers and through my headphones connected to the Zed 10. I assumed it was everything but the mixer, but I came to that last and swapped it out for a little crappy Mackie mixer - clean sound straight away.
The only thing I can say is I remember when I first connected everything up and started using the Zed 10 again a few weeks ago, there was loss of signal on my headphones which was only rectified by turning the volume right up and over-loading the channel - then bang - volume comes back and I'm able to hear at normal levels.
It looks to me as if there might be a bad connection inside zed 10, maybe a component failing, any idea where I start? It's out of warranty now.
Cheers
Cheers
