J
jimmychan
some of these may be a bit obvious but i'm just starting
I'm running cubase 5 on win 98ME, 1.3Ghz AMD TBird, 512Mb Ram with a SB Live card
Running the direct X full duplex driver I get a 46ms latency which is pretty good (I think) but sometimes it can be noticeable when using the automated mixing stuff. If, say, I get the volume on a channel to change at step X.x.x (as stated in the event list) the actual change in sound when the song plays through occurs noticeably later - I presume this is due to the latency. Is there any way I can automatically shift all the events for the automated consol back by that amount of latency (worked out in the step time format) so as to make the actual events occur in the correct place?
Also, does the latency affect only audio, or will it apply to midi input as well (i'm thinking of getting a midi keyboard), meaning that all midi input events recorded in realtime would have to be shifted back to account for this?
Thanks for any help.
Jim
Jim
), read up on latency in the documentation. I am pretty sure there is some solution to your problems. You can't get rid of latency but I am almost positive that there are settings that will take care of your dynamics and automation and make them operate in correct time.
