Latency Problems
  • Thread starter Thread starter stiletto107
stiletto107
Hello, I am experiencing latency issues while recording in my home studio.
Here is my setup...
PC with XP Pro and a gig of ram.
PC has two hard-drives. Operating system on seperate hard-drive than my recording software. I have also turned off many services to try and reduce problems there.
I am using a FirePod as my external soundcard which is fire-wired to my PC.
I am using Cubase SE3. I am also using BFD for my drum plugin.
I have my Roland V-Drums connected via MIDI to my FirePod.
I have Cubase route my MIDI output to BFD so that I can use the BFD drum sounds.
Ok, so I usually start off by recording a scratch guitar track to a metronome.
Then maybe a bass guitar. Now, if I record the drums with just those two tracks on the screen, my latency problems are rare. But if I were to record a whole bunch of audio tracks and then record the MIDI drums, I always have latency. But not in the way that I would expect. The MIDI track is always AHEAD of the audio which was already recorded. So I would have to then try to nudge the MIDI track back to line up with the metronome.
Make sense? Having to take this step is a pain and is very time consuming.
I will mention that I tried just snapping the MIDI to a grid in the drum editor, but that makes the drums sound like they were played by a robot. It just does not sound natural.
In the control panel for my Presonus FirePod, there are two options that can be tweaked... The first option is basically the quality of the audio file and the other is labeled "Latency". I have had it set at 4. I have tried having it set at 8. But I don't know what it really refers to. Is it a buffer size and if so, what should I most likely set it to? Is it used to set an allowable latency in increments of milliseconds?
I appreciate any help, and sorry if this is the wrong forum for this.
Increasing your latency setting on your Firepod won't improve your latency, it will just make it worse. The setting refers to how many ms you want the Firepod to allow for processing - set it as low as you can without hearing any glitches or breakups. So, it's the second of the things you suggested.
It sounds to me like the issue *might* have something to do with the way the audio is coming out of Cubase... maybe plugins are adding a lot of latency or something? Not sure. It should be compensating for system latency when it's record your MIDI but if it's not then there's a problem somewhere, maybe a plugin that's not accurately reporting its latency or something. Do you have any plugins on the audio tracks when your doing this recording? Do you get different results when you remove them?
How about if you mute the audio tracks 3-10? Same result?
