C
chamelious
www.thesunexplodes.com
Im using cubase SX and was having problems before which i attributed to on board sound but since im having the same problems with my delta 44 i asuume the problem is elsewhere.
Sometimes right away, and always after a while recording, say2-3 tracks worth at best i start getting synch problems. What happens is a record a part whilst listening back to say a drum track, then when i play it back the part i've recorded is out of synch with the part or parts ive previously recorded.
I just noticed in my project settings its set to 32bit floating, i realise this should be at 24 or probably 16 but should this be causing a problem?
