Some ISIS tips and queries
Heya ppl, I just discovered this great site and thought I'd add my 2 bits worth in this thread first.
Yah Spider, nice call on the DMA bus mastering. Did you know that all HDDs and CDRs and CD ROMs in your system will work better together if they are ALL DMA enabled? (I only found that one last week)
I also use the ISIS card and have had HUGE problems getting going, the support sux as do the drivers.  The 1.6 version ASIO driver seems to work better for me than the 1.8 version (bout4 more tracks or 2 to 4 plugs).
ASIO 2 will allow you to use the new Direct Monitoring feture in VST24 and 32 (WDM format). With this you can monitor through cubase with FX and minimal latecy in real time.  There are rumors of Guillemot releasing ASIO2 in the next month but that ain't official and they've never delivered before ie; Win ME drivers. I ain't holding my breath.
I saw you said that the multimedia driver was more stable for mixing than the native ISIS one. I aggree, but when you load the ISIS driver does it make the CPU performance over light come on, even with a blank arrangement? Mine does and it pisses me majorly!  It also pops and crackles once I start to load up on the DX plugs. As a result I am using the Multimedia driver almost exclusively but the 500+ ms latency is a pain.
I still get problems with sync sometimes, but only when I'm running too many FX or tracks.......
As for FX check this out, FREE verb! literally and it knox the sox off any others I've tried, waves, timeworks, native ect. Really low CPU usage, anyway I like it
http://home.onet.co.uk/~jzracc/plugins/index.htm
Can you get the ISIS to bus to outboard FX then back into cubase without feedback? I've tried all sorts of different settings but as soon as I try to hear what I'm doing ie; putting eq on a drum submix (and you NEED to monitor this)I get this horrible feedback, I tried on the ISIS based forums but no-one really uses Cubase there.
Yah I have had the same trouble with Maxbass, but I think it doesn't give more than it takes in CPU so I don't use it, try Magneto instead with the 30ips setting mmmhmmm FAT AS!  Great for Kits too but
Quadra Fuzz is my fav there.
Anyways greetings from Melbourne and I hope there's something you can use amongst my twaddle.
Bones
