Whoopysnorp
It seems that my setup does not allow me to take advantage of the low latencies promised by ASIO. I have an IBM Aptiva that I've been gradually converting into a machine suitable for recording. At the moment it has a 700 Mhz Athlon in an Anigma S30 mobo (AMD Irongate chipset), 352 MB PC100 RAM, 5400 rpm 17 GB HD (apps & OS), 7200 rpm 40 GB HD (audio), DVD-ROM, CD-RW, 200 W power, TNT2 M64 16MB video, SBLive Value, Delta 66, cheap ethernet card, Win98SE. I've done the typical optimizations: the HD is formatted in 32k clusters, I have a separate hardware configuration and user profile for recording that reduces hardware and things running in the background, etc., etc. I can't use any latency below 20ms, which drives me nuts when applying plug-ins. I've heard people claim that they don't have any problem using latencies like this--I suppose if I put effects on everything, so I couldn't hear the delay between the same sound on two channels, I'd be OK. I think the problem may be the weird motherboard/old chipset/100 Mhz bus speed. Any other ideas, or will I just have to grin and bear it?
