W
Wallbagner
Hi there,
I had a very similar problem with my samsung laptop and the cause was of course the power supply.
So what i did to resolve the problem was to remove the round pin of the power supply's ac
cable, some switching power supplies generate noise on the ground pin causing this problem.
Alway be sure to orient the cable plug in the same way as if it had the round pin, the larger pin on the is also return.
(ie: ground).
ince then i have no more funny noises thru the pa system.
My 2 cents worth!
(ie: ground).
My 2 cents worth!
