studiomaster
I need to know which one of the following monitors is better in mixing. I'll be getting one of them this saturday so i need your opinions.
TheDewd said:Neither.
Both are awfully cheap and use too small woofers for you to hear what's going on down low.
SouthSIDE Glen said:Studiomaster,
If you are heading to a dealer to pick them up, take some of your fav commercial CDs with you as demo material and compare them at the dealer to see which ones work best for you. Everybody's ears and tastes are different.
If you have to order them by mail or online, order one of each. Then check them out in your room and see which one works best for you. Then return the one you don't want in exchange for the one that you do. Even if you have to pay a couple of bucks for the second shipment, it's worth it to know you're getting what you really want.
G.
Well, monitors ARE the most critical part of your setup.studiomaster said:Oh just shutup please. I'm tired of you suggesting $2000+ monitors everywhere in the damn forum.
TheDewd said:Well, monitors ARE the most critical part of your setup.
It show that you are not THAT serious about getting a FLAT and ACCURATE response.
Dude, for this amount of money, the monitors you buy are no better than cheap home theater speakers. If those were $300 PASSIVE monitors, then it would make some sense, since the amps are the most costly component in an active monitor. So you get $200 worth of amps, transformers, transistors, etc...and $100 of ACTUAL speaker design.
What makes a good speaker is the quality of the design...so there you have your answer.
I use a High quality flat and accurate headphone system.studiomaster said:Really...so what monitors do you use?
I hate nearfields and in order to get a nice bass going on, you have to use headphones or AT LEAST a 12 inch woofer or small thingies with a sub.
You have now been added to the list of people who are no longer allowed to ask why your mixdown CDs don't sound as good or as loud as commercial CDsace516 said:we ARE after all, home recording engineers not professional studio engineers.
. You have just given your own answer.
I guess this is why NS-10 users have to be "really" careful of the lows (most often they high pass everything at 60 Hz).Bob's Mods said:Unless your stuff is extremely low frequency they should work out fine. I've had no bass balance problems when going to other systems.
