King Tubby HP Filter
kip4
Looking for a budget preferably diy solution to an altec 9069 alternative
for making Dub.
any ideas welcome good people.
Thanks
Rich
Maybe there’s a ”better” in the box solution the nearest two ve come to what I want yet was the waves GTR plug in automating the freqauncies on the tone pedal or adding an amp sim and automating the amps freqauncie sweep.
Daw Reaper.
controllers arturia minilab 3 and mpd 218
Have you tried the filter on ReaEq? If you make it sharp enough by lowering the bandwidth you will end up with a little resonance which makes things interesting.
As it happens I have mate and it’s good too. Takes a bit of tweaking the parameter sensitivity. I also tried it with the pre 73 EQ (Arturia, not affiliated)
im getting some better results with the readelay when using a midi controller.
learn.
feedback
wet
dry
Im hoping to save some good fx chains from these experiments that be a good macro (starting point)
Thanks for that.
