Farview
How many feet per millisecond again?
ermghoti said:Close enough to 1. Speed of sound varies with altitude and humidity, but 1000fps is about mach 1.
For beater click, tape a quarter to the impact point.
Farview said:You will never get any attack on the kick playing with a felt beater (especially if he isn't a heavy hitter). You should put the 57 1 or 2 inches off the batter head. This might help isolate it enough so you can turn it up in the mix. You will need to take out some 400hz on the 57 to make it sound right. (ymmv) The drummer might have to make an effort to hit the drum hard enough to make it speak the way that it should.
SRR said:Phil I am always amazed at your drum sounds, and thats with cheap mics like the superlux.
Take the 57 and mic the shell of the snare drum. (if it has a vent hole, point the mic at that) Don't worry about the hi hat, get the mic within an inch of the snare.pointfive said:Usually I set up 4 or 5 mics: 1) snare/hit-hats (57); 2) and 3) kick (57/subkick); 4) room mic (usually a Rode NT-1A between 4' and 5' in front of the kit--I do this instead of the traditional 2 overheads); 5) depends on the song and which part of the kit I want to accentuate. For ride-heavy songs I'll point it at that.
reshp1 said:For sound. For light/electricity it's 983571![]()
Mic the shell, not the head? Okay, I'll give this a shot.Farview said:Take the 57 and mic the shell of the snare drum. (if it has a vent hole, point the mic at that) Don't worry about the hi hat, get the mic within an inch of the snare.
We usually track each instrument separately against a click track, so the room mic doesn't pose a problem. It's a limited setup admittedly, but we're working with what we have.Farview said:If you EQ the room mic so the drums sound good, everything else coming into the mic will sound weird. You will also run into phase problems with the guitars, bass and what ever else you have going.
Gotcha. In the song I posted, I actually mic'ed the floor tom, but not close. (There wasn't much ride in the song, so...) But I'm taking all this advice very much to heart.Farview said:Just a side note: The hat and the ride are not normally the focus of a drum set. The kick and the snare are. With what I heard, the hat and ride will cut through just fine without any special attention. You need to get the kick and snare working together to drive the song and fill in with the cymbals.
Yeah, the drums in that clip did sound really good.SRR said:Phil I am always amazed at your drum sounds, and thats with cheap mics like the superlux.
What you could do is record the mics to separate tracks, play a little bit and listen back, checking for phase. Once you have gotten the drums sounding good and you know the setup works, then buss everything to two tracks and record the song. It is a long way of doing it, but it's better than recording a song with bad drums.pointfive said:What you explained about checking for phase problems answers a question I've had for a long time. Thanks so much. It'll be tough to do this at first, since our mixer and monitors are basically right next to the kit (thus the sound hugely bleeds through the headphones), but with a few test takes we should be able to accomplish it. At least I know what to listen for now.
ermghoti said:Edit: I beleive light/electricity would be closer to 948,600,000 ft/sec. (186,000 mile/sec). Nyah.
