Ketron SD2 connect to Tascam DP03 digital recorder/mixer:advice please.
  • Thread starter Thread starter Denv12
D
Denv12
I bought a new Ketron SD2 sound module.I connected it up to my Roland stage piano.Its going great.I have 2 guitar leads running from piano to Tascam DP03 digital recorder/mixer.Then an XLR mic to DP03 as well.From the DP03 to the amp is connected by a dual RCA lead to the amp.I can use dual RCA's at one end to dual guitar plugs at the other or dual RCA's at both ends.They all work.When I want to play/record I just switch on RD700SX,Roland amp and Tascam DP03,I switch on track 1 and 2 to play.If I want to record I go through the DP)3 menu,create song then press record and play.
With the Ketron SD2 it has 1 MIDI cable from SD2 MiDi in to Piano Out 1.
A dual RCA lead from SD2 L R to amp.Its how its done.
When I tried to record onto the Tascam and played it back.I could hear the mic but barely hear the piano/SD2.I tried adjusting the levels on the DP03 but that didnt help.It seems there's a need for a cable to run from the SD2 (RCA) to the DP03.I cant plug anything else into the DP03,there's only an XLR socket left.I need to get the SD2 to the DP03.Is anyone familiar with the set up?
Thanks.
Update:Feb 5.Problem solved.
