just ordered two stacks of owens 705 - seeking advice
  • Thread starter Thread starter question444
Q
question444
I just bought twelve panels of Owens Corning 705 rigid fiberglass. (2' x 4' x 2") I have a rehearsal room that is also used occasionally for recording. The room dimensions are approximately...x: 10' y: 15' z: 9'. My plan is to cut right-triangles and stack them in the three available corners of the room. (Each wedge would be 5.3' tall and 2' wide.) If I were to cut the triangles smaller (1.4' wide), I could stack them all the way to the ceiling.
As you might know, this stuff is a little expensive, so before I go cutting, I'd be very grateful to hear anyone's suggestions as to how I should configure this material. Thanks a lot.
I personally would just keep the 2x4 panels in-tact,cover them and stradle them across the corners. You could then go floor almost to ceiling with 2 panels stacked on top of each other (8ft high). You would use 8 panels for the 4 corners and then you could hang the other 4 panels on the walls. When you can afford more, just double up in the corners for 4 inches of thickness.
Don't know your room layout though, I'm sure the triangles would work too.
Now let's here from the experts....
Doing 16 small triangular pieces of each panel (40x30x30 cm)?
I did it,but after changing for 2'x4'x 4" with air gap the (measured) absorption was improved.
It confirms what I use to read about ... seems 2' wide is the "minimun" way to go.
Ciro
re:
thought I'd post my room setup...
Does anyone know why 705-FRK is rated much more absorptive than plain 705 ?
(attached owens corning absorption coefficients) Will they compare more similarly in bass frequencies (below 125hz)? I have the plain 705, and I'm wondering if I should have gotten the 705-FRK. These will be used for bass traps.
